Finding parts to put in my new computer. Can someone please help me
  • Water Cooling
  • Computer
  • Overclocking
  • Product
December 17, 2012 12:31:37 AM
Hello, so i'm building my first gaming computer and i'v planned a list of stuff that i'm thinking of getting. I already have a case so i'm really wanting to see if it will all fit. But here is the parts and please tell me if i'm missing something important.
NOTE: I was planning to get water cooling. But i had a feeling it won't fit so i chose a fan. If you guys think i can put watercooling in please let me know.
My case so far: Raidmax Seiran - http://www.raidmax.com/chassis/seiran.html
MoBo: ASUS P8Z77-V DELUXE LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel
Motherboard - http://www.newegg.com/Product/Product.aspx?Item=N82E168...
GPU1: EVGA Superclocked GTX 680 - http://www.newegg.com/Product/Product.aspx?Item=N82E168...
GPU2: EVGA Superclocked GTX 680
PSU: Corsair HX1050 CMPSU-1050HX -
CPU Cooler: Cooler Master Hyper 212 Evo - http://www.newegg.com/Product/Product.aspx?Item=N82E168...
CPU: Intel i7 3770k Hard Drive: Western Digital Caviar Black WD1002FAEX 64MB 1TB Solid State: Samsung 830 Series MZ-7PC128 128GB
RAM: CORSAIR Dominator Platinum 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 1866 Desktop Memory Model CMD16GX3M4A1866C9
So what you guys think? I just need to know if its all going to fit and if so can i fit in
watercooling while using that case?
Thanks so much for your time :)
More about : finding parts put computer
December 17, 2012 12:47:15 AM
amuffin said:
Have you read the watercooling sticky?
http://www.tomshardware.com/forum/277130-29-read-first-...
You're going to have to go with an external setup, with around 480mm of rad space.
Ok i'll give it a read thank you. But with the parts i have chosen.. will my computer be ok when built? I'm not sure if certain parts need others to actually work
m
l
a c 178 K Overclocking
December 17, 2012 12:48:15 AM
Are you willing to mod the case?
Because otherwise it seems all your rads will have to be externally mounted. With some modding you may be able to get a dual rad at the top of the case internally.
Wrong forum for that kind of advice, you want the Systems forum. But yes all the components are compatible with each other.
m
l
a c 150 K Overclocking
December 17, 2012 12:50:28 AM
What's the point of 16GB at 1866mhz?
m
l
December 17, 2012 12:51:45 AM
well, how much is your budget ?
if you gonna spend that much! why not get a big case for FULL water cooling loop ?
you are gonna do SLI with GTX680 or just running a single GPU.
In my opinion, I would pass that case to something more space but if you like that case ? well, be prepare to do some modifications.
good luck
m
l
