darth pravus :
That seems to come with everything you need. Obviously more fittings and blocks are needed if you want more things in the loop.
Not sure what you mean by order of flow as that's only a CPU kit but you can use a splitter to send one flow to the CPU and one to the GPU and rejoin for the rad so they are in parallel.
By that I mean what part of the cooling should go first?
Like should the pump, pump directly to the CPU then cool the water or the other way around?
I Also Have 2 More Questions:
1. Should I use Liquid Ice or distilled water?
2. Should I cycle it with water, then dump it out and put in new water so I can get any dust out of the loop?
