Hello,
Not sure if this is the correct section but last week a bought/made a new system, the mobo was a Gigabyte GA-880GA-UD3H and 4GB of Ram (A-RAM).
A-RAM 4GB KIT ( 2 x 2GB) DDR3 PC-10600 (1333MHz), ECO, 240-pin RAM non-ECC CL9, high performance IC,
Up untill today this setup was working fine with a few exceptions, however while the system was in sleep mode, i had to cut power to the psu.
Upon rebooting i faced 3 long beeps which according to my manual it is a video card or short circuit error, i tracked the problem down to 1 of the 2 RAM sticks.
The 3 beeps had happened once or twice since i made the system, which resolved itself untill this time. Is the cause of my problem a faulty manufactured RAM stick or a broken RAM stick caused by loss of power or my setup?
further info
The RAM were placed in the DDR3 1-2 slots, it was the second slot/card that seems to have died. That first RAM works by itself and the second RAM doesnt. if combined, i get the 3 beeps.
CPU: AMD Phenom II X6 1055T
With windows 7 64bit on a 64GB SSD.
further info
