Sign-in / Sign-up
New PSU and graphics card help
  • Graphics Cards
  • Packard Bell
  • Graphics
  • Product
Last response: in Graphics Cards
February 17, 2010 7:02:10 PM
I have a packard bell ixtreme x5620uk pc, and would like to get a decent graphics card, preferably 512mb and above, and possibly a new psu.
I got my pc in Dec 2009, and i see from the case it was manufactured in Sept 2009, so it is new.
I know i have asked which graphics card i can run on it(i think it has a 250w psu, but not sure). But if i did have to look at a psu, what would i need to look for, and what would be suitable for my pc(so as not to damage the pc), also what graphics card would be ok - i think my pc is micro atx?
My spec is :
Intel core 2 quad 2.5ghz, 1333mhz, 4mb cache
windows 7 home premium 64
4gb ddr2 ram
640gb hdd
nvidia 7100 integrated graphics
More about : psu graphics card
a c 130 U Graphics card
February 17, 2010 7:06:25 PM
Monitor's resolution and budget?
February 17, 2010 7:11:09 PM
resolution is 1366x768 max. Not sure of budget, but as cheap as possible, as am not serious gamer, but have just been bought tomb raider underworld and it is laggy - requires 256 mb of dedicated graphics card. To be honest, i think it may be more realistic to look at anything from 256mb up - what do you think.
February 17, 2010 7:19:58 PM
HD5570 is $80, and should be fine.
February 17, 2010 7:22:16 PM
Thanks for that - will the hd5570 run on the 250w psu with no probs - also, forgot to ask, does it matter if the card is ati or nvidia?
