Problems with CPU temps
Last response: in Systems
Im currently having issues with my desktop computer and the temperature of my CPU.
the hardware im using is;
Abit aw9d mobo
ati radeon power colour 4850 1gb
6gb of ddr2 ram at 800mhz
intel q6600 quad core 2.4ghz
two 320 gb harddrives a maxtor and a western digital
900watt psu
The temperatures for my cpu is being read at 60deg on idle in bios according to the built in uguru software on the mobo. I have tried putting in another cpu a single core at 2.8ghz and that was running at 70deg :shock:
After checking the voltage levels being put into the cpu i notcied it was overclocked, i can't remember the exact figures but it wasn't what it should have been normally. This could explain why the cpu was reading at such a high deg but i am not 100% sure as to the touch there was no way the heatsink was at this temperature or anywhere near it, more like 30-40deg and with a temp gun it read at 35deg (not that reliable though as they dont work great on shiny surfaces) I tried with a water cooling system and with a low profile aluminium fan and there was little difference between the two.
I first thought that the uguru readings where inaccurate as i have previously said when touching the heatsink it was no way near that temperature and the system had been running for under 1 minute.
When trying to install windows 7 it would keep freezing from 1-2 minutes after it started loading, there was also a heat sensor alarm triggered making a beeping noise.
Before all this started i had the system running for around two years at an idel temp of 40-50 and when playing eve or other games a temp of 55-68.
This would have been using the settings on the mobo that had it overclocked so i am a bit worried if my cpu is now shot and i will need to get a new one or not.
tldr: cpu been overclocked with out knowing for two years and is now running very hot am i likely to need a new one?
More about : problems cpu temps
try HW monitor to check the temps, pretty precise readings.
also, in the bios there should be a way to reset everything to defaults, if the voltage is higher than normal, thats the reason for the extra heat.
I doubt you need a new CPU. The Q has a max temp of 70.1C I believe, but I'd take a look at your BIOS setting like JDV said. My Q is at 32C idle right now, and it's clocked to 3.2Ghz.
Thanks for the reply's guys, i assume the HW monitor is this
Since i posted my original question i thought about the problem a bit more and considered that the uguru program might be giving false figures.
Originally i managed to boot into ubuntu which was allready installed on my second hdd, i was going to load it up again then leave the computer to play a dvd and see if it could, if this works i would imagine that the dvd drive is ok, i might also try running a different version of windows 7 installation disk just incase the disk i was originally using was faulty, even though i doubt this would explain the computer locking up. Is it worth me doing all of this or are these un likely to do anything for my problem?
Cheers.
Ask the community
