G
Guest
Guest
Ok, so Im building my first HTPC. Here are the capabilities I require...
Current:
1) Read video_ts files
2) Play hulu and netflix. Im looking for a mobo that can do hulu full screen--I know their flash player has some problems with hardware acceleration.
3)excellent picture quality-- full 1080p on a 52" hdtv
Future
1) Upgrade to windows 7
2) TV tuner for OTA and/or Cable tv with recording
3) bd-rom
This is what i have
52" Samsug HDTV
80gb hard drive for windows and programs. media to be on another HDD.
Here's what i think i will be needing.
mobo- GA-MA785-UD2H http://www.newegg.com/Product/Product.aspx?Item=N82E16813128394
Chassis- nmedia 2000b http://nmediapc.com/htpc2000.htm
HDD- WD 1TB http://www.wdc.com/en/products/products.asp?driveid=488
Memory- Cheap 2x2gb
dvd-rw cheap liteon product LiteOn iHAP322
PSU- atx 600w
cpu fan- ?
Im really looking to see if my mobo can handle what I want to do.
Also, what kind of cpu will I need? I was thinking Athlon II.
Thanks i really appreciate everyones help sofar
Current:
Future
3) bd-rom
This is what i have
52" Samsug HDTV
Memory- Cheap 2x2gb
PSU- atx 600w
cpu fan- ?
