Help with case, First Build
Hello, After a bit of research, I decided to build a computer. Everything is working pretty well, Except the front fan on the case makes a loud clicking noise. The case in a Xclio A380 Color, and I'd would appreiciate any help you can provide.
2 answers Last reply
More about help case build
  1. Is the sound continuous.? In that case the fan blades might be touching on some wire or some other stuff while in motion.. The noise may be electrical also in which case you should check the fan power connector.. If it uses a standard molex then try using some other molex connector..
  2. I managed to fix it by removing the wire mesh in front of the fan, thanks for the help anyway.
Power Supplies Cases Computer Build Components
