Hi
I want to clean the inside of my block but have never opened a waterblock before. It looks easy enough as there are only four screws to remove but what I am worried about is getting it back together safely. Is it easy to reseal it nice and watertight with the existing o rings in place or is it a bit fiddly and likely to leak so best left alone?
If anyone has any experience opening this block and getting it back together afterwards your input would be appreciated.
Thanks in advance
Mag
Thanks in advance
Mag
