Replacing damge harddrive with new-problem
Just bought a Seagate - Barracuda 1TB Internal Serial ATA Hard Drive to replace a broken harddrive that came from computer.
I only have the recovery disks for vista and a Upgrade disk for windows 7. When i use the recovery disk for vista it cant find the drives, Im lost to what to do next.
The old drive was getting errors like, Insert boot media and select proper boot order. The boot order is correct inside the bios. Im not sure if it is actually a motherboard problem or has the hardrive failed?
3 answers Last reply
More about replacing damge harddrive problem
  1. The recovery is on a separate partition on the hard disk.
    You need to clone the old hard drive on to the new Seagate 1 TB and then proceed.
    More info here: http://www.apricorn.com/products/notebook-hard-drive-upgrade-kits/drivewire-ide-pata-sata-to-usb-hdd-adapter.html
    Is there anyway I can reuse my product key from my old hardrive... and reinstall windows 7 to a new one. I just need to get my hands on a new windows 7 installation disk.. Anywhere I can get it without paying 200$ since i already have a product key...
    That in effect would be "transferring" Windows 7 from one computer to another, and will not work.
    OS pre-loaded by manufacturers like HP, Dell, etc. are "dedicated" to that particular computer and cannot be transferred.
Hard Drives Boot Windows Vista Storage
