Solved
Crosshair IV Formula wont power on
I can't seem to get the pc to power on. When I attach the power supply and attempt to turn it on nothing happens. The reset light on the back of the motherboard is lit green and all of the onboard switches are lit and do not turn off. The motherboard's start switch is supposed to blink several times before you should power it on but it just stays lit along with the other lights. I have checked all the connections several times and everything is connected correctly.
My system specs:
AMD Phenom II X6 1090T
Asus Crosshair IV Formula
KINGSTON HYPERX 4 GB DDR 1333
ATI RADEON HD 5850
BFG GS-650 PSU
THERMALTAKE DUORB CPU COOLER
Any help would be greatly appreciated thanks
2 answers Last reply Best Answer
More about crosshair formula wont power
  1. Best answer
    Seems like a 'Short' - so remove ALL of the mounting screws and 'dangle' from the I/O shield & mountings <or> breadboard on cardboard; and try to start.
  2. Best answer selected by brix4lyfe.
Asus Power Motherboards
