In a couple of weeks i will be purchasing parts for a water cooling loop setup. But this i my first loop setup and i am a little nervous, so any and all advice is appreciated. Ive read a lot here on the water cooling forums on this site and other sites but i don't really see any reviews on the parts im looking at and that leaves me feeling uneasy. and a down side is im am on a budget of about $200 but i dont mind going over for stuff like tubing, barbs, coolant, and other easy to obtain items. And For most of the parts i am buying off the Frozencpu website.
For the moment im just trying to cool my amd 6970 BUT later on when im either upgrading or building a new rig id like to water cool more items such as high end graphics cards in SLI/CROSSFIRE setup and a high performance CPU (probably going to be OC'ed). so im trying to buy parts that will last and support my next build.
Heres the items ive selected so far.
http://www.frozencpu.com/products/13692/ex-pmp-142/Phobya_DC12-400_12V_Water_Cooling_Pump_-_DC12-400.html
http://www.xoxide.com/primoice-nonconductive-fluid-clear.html
http://www.frozencpu.com/products/14916/ex-rad-334/Alphacool_NexXxoS_XT45_Full_Copper_Single_120mm_Radiator.html
http://www.frozencpu.com/products/15647/ex-res-351/Alphacool_Repack_Single_525_Acrylic_Reservoir_-_Clear_-_Version_2_15039.html
http://www.frozencpu.com/products/2122/ex-mis-02/12_ID_-_58_OD_PVC_Clear_Tubing.html
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103069 (radiator fan)
Note: all these items are coming already equipped with 1/2 inch barbs with g1/4 threading.
And is 1/2 inch ID enough to cool multiple components?
