Solved
What is the recommended power supply for my pc
I'm gonna buy this components, but i don't know what power supply i can use.
CPU core i7 860
M.B GA-P55-UD3R rev. 1.0
RAM 4GB DDR3 bus 1333
H.D 1tr 7200 rpm
VGA ati 4670
Could you please help me to choose a power supply for me? ,and any comments on my components.
4 answers Last reply Best Answer
More about what recommended power supply
  1. A decent 500-600W from Antec, Corsair, Seasonic, PC P&C, Enermax, or OCZ should be fine.
  2. Best answer
    ^+1 With those specs you won't need a lot of power. The key is to find a quality PSU made by a reputable company, and blackjellognomes has given you some (Seasonic, Corsair, PC Power & Cooling, Antec, etc). If you're not going to be pushing for large overclocks and if you don't plan to upgrade to a more powerful and power hungry GPU, you could even go for lower W.
    I have a similar build and I typically idle around 70-80W, pushing things in stress testing I've not topped 200W. I opted for the Corsair 450VX ( http://www.newegg.com/Product/Product.aspx?Item=N82E16817139003&Tpk=Corsair%20450VX ). This is the review that sold it for me: http://www.hardwaresecrets.com/article/540
    Two good sites for researching PSUs are:
    http://www.jonnyguru.com/
  3. thank you very much guyz
  4. Best answer selected by muh.
New Build Power Supplies Components Systems Product
