Solved
Question about CPU COOLER and RAM ???
can I in stall Ram 1st then CPU Cooler?
6 answers Last reply Best Answer
More about question cooler
  1. yes you can
  2. Yes
  3. Best answer
    Yes you can install them either way around. It's probably easier to install the RAM first, particularly if you have a large aftermarket cooler since it can quite fiddly with your cooler in the way.
  4. Yes,, if you have the stock cooler or an aftermarket one of reasonable size (eg cooler master 212, etc)
    No, if the aftermarket piece is insanely huge (cooler master V10, etc)
  5. Thanks... I have an large after market one and installed RAM 1st and build went fine
  6. Best answer selected by Foxmulder13.
Cooling RAM CPUs Components
