So I've been talking with my friend about upgrading my pc specifically for FFXIV. I already did my GPU (EVGA GTX460 1GB Superclocked) and my CPU (AMD 955 Quad Core). The game still runs like crap... So he said it was my RAM which is DDR2 800. After a long time thinking and finding out that some Nvidia cards wont work in an ATI based motherboard (I have an ati Based Motherboard = http://www.newegg.com/Product/Product.aspx?Item=N82E16813128395) I've decided to do the only thing I can think of.. Get a new Motherboard and DDR3 1600 RAM.
My friend said that this Motherboard: http://www.newegg.com/Product/Product.aspx?Item=13-130-235&SortField=0&SummaryType=0&Pagesize=10&PurchaseMark=&SelectedRating=-1&VideoOnlyMark=False&VendorMark=&IsFeedbackTab=true&Keywords=ddr3+1600&Page=1#scrollFullInfo
Is an awesome motherboard that he used for 4 builds and it works with this RAM: http://www.newegg.com/Product/Product.aspx?Item=N82E16820231277
The only thing is.. When you read some of the reviews it says that this Motherboard is (O.C) 1600 DDR3 RAM. But he and others say that the 1600 will run in there fine, plus hes done this 4 times. I just want this extra reassurance that that ram will run its fullest in the motherboard without any overclocking (He didnt have to overclock it) cause I dont know anything about overclocking.
At this point Ive basically rebuilt the entire PC... Will this motherboard and RAM Last me the 3-5+ years that the GTX 460 1GB and 955 CPU will? If Not or If you know of a better Mobo and RAM that would be awesome too.
Sorry for my poor grammar and spelling, and thank you ahead of time.
Justin
Justin
