Motherboard Problem Help !
  • Motherboards
  • Asus
  • PCI
October 21, 2010 1:01:16 PM
Hi
I just built my new pc yesterday, but my Gefore GT 9600 didn't work on the ASUS P6X58D-E on PCI x16-1 or PCI x16-2 which are the blue ones, but it did work on the white one which is PCI x16-3.
And i just want to know why ? is my motherboard broken or what?
Thanks for any answer :)
More about : motherboard problem
a c 435 V Motherboard
a b Ĉ ASUS
October 21, 2010 1:58:19 PM
Read your board manual if it has more than one pci-e slot. It should give you the recommended options.
a b V Motherboard
October 21, 2010 4:02:00 PM
It's supposed to work on PCIe x16_1 & _2. What does it do when you connect it in 1 or 2?
Slot _3 only runs @ x8 max.
a c 717 V Motherboard
a c 207 Ĉ ASUS
October 21, 2010 4:30:35 PM
Hmm, that is odd. I only have (3) possibilities that come to mind:
1. BIOS - did you make any changes to the PCIe {settings}?
2. Voltage issue {including partial 'short' / installation}
3. Conflict with 'other' PCI installed devices
Try: {Put the GPU back into the first slot}
1. BIOS - Load Defaults
2. Failure remove ALL mounting Screws and dangle MOBO then restart
3. {Verify GPU is connected to the PSU}
Default Settings:
IOH PCIE Voltage [Auto]
ICH PCIE Voltage [Auto]
PCIE Spread Spectrum [Auto]
PCI Express Selector [Auto]
I have several of these MOBO and I have no problems, nor have I seen this issue before today.
October 21, 2010 10:14:24 PM
It goes without signals like it's not conected
October 21, 2010 10:19:28 PM
Default Settings:
I'll try and se if it's works thanx :)
but there is a problem if I remove the card and put it i the PCI x16-1 it will go with no signal and then I can't see any BIOS or anything runs =(black picture)
a b V Motherboard
October 21, 2010 10:31:08 PM
No sounds, beeps, fans turning on or anything of that sort?
October 22, 2010 1:51:47 PM
everything goes on, even the card but it gives no signal.
a b V Motherboard
October 22, 2010 2:22:28 PM
Have you tried cleaning it with some Isopropyl alcohol? I'd try that - though it seems unlikely that's an issue - but worth a try.
a b V Motherboard
October 22, 2010 4:27:42 PM
^ yeah. it would probably be the best idea =P you kinda need those PCIe to work lol
