Yes No
Ads
Tom's Hardware > Forum > Systems > New Build > [Solved] First System Build -- Please Advise
Forum Systems : New Build [Solved] First System Build -- Please Advise
APPROXIMATE PURCHASE DATE: Sooner than later. No extreme rush.
BUDGET RANGE: $1000
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: Gaming, surfing
PARTS NOT REQUIRED: Keyboard, Mouse, 24" Monitor (x2), Going to reuse 36gb Raptor for OS drive, Speakers
PREFERRED WEBSITE(S) FOR PARTS: newegg.com USA
PARTS PREFERENCES: Intel CPU, ATI Video Card
OVERCLOCKING: Maybe. This system is a huge upgrade to what I have currently so I may not.
SLI OR CROSSFIRE: No
MONITOR RESOLUTION: 1920x1200 (I would like to drive 2 24" for everyday computing but not gaming)
ADDITIONAL COMMENTS: I want to stay under $1000US. Present total is $1004 without shipping. Going for pure functionality, no lights, windows, bling, etc. necessary. The case can change if there is something out there that is mellow in style. Thanks for your help.
Edits: Changed Hard Drive to Seagate. Changed memory to CAS Latency 7 Ripjaws. Changed to ASUS mother board. Split up power supply and case combo.
ASUS P7P55 LX LGA 1156 Intel P55 ATX Intel Motherboard - Retail
GIGABYTE GV-R585D5-1GD-B Radeon HD 5850 (Cypress Pro) 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card w/ATI Eyefinity - Retail
Intel Core i5-750 Lynnfield 2.66GHz 8MB L3 Cache LGA 1156 95W Quad-Core Processor - Retail
G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model F3-10666CL7D-4GBRH - Retail
Seagate Barracuda 7200.12 ST3500418AS 500GB 7200 RPM 16MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
SAMSUNG Black 22X DVD+R 8X DVD+RW 16X DVD+R DL 22X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache SATA CD/DVD Burner - OEM
Microsoft Windows 7 Home Premium 64-bit 1-Pack for System Builders - OEM
COOLER MASTER Centurion 5 CAC-T05-UW Black Aluminum Bezel , SECC Chassis ATX Mid Tower Computer Case - Retail
COOLER MASTER eXtreme Power Plus RS-460-PMSR-A3 460W ATX12V V2.3 Power Supply - Retail
Message edited by bcrosbie on 03-04-2010 at 01:04:18 AM
Reply to bcrosbie
Switch the WD for a Samsung Spinpoint F3 or Seagate 7200.12 500 GB. Both are faster, quieter, cooler and cheaper.
Get the CAS Latency 7 Ripjaws for only $10 more.
I would recommend looking at an AMD build and getting an HD 5870 for your resolution. If you still can't fit it with an X4 955, don't feel like you have to have the top of the line CPU. The GPU is the most important part to gaming.
------------------------------ How to Ask for New Build Advice
Troubleshooting
Reply to MadAdmiral
Using that old Raptor as the system drive is not a good idea. Unfortunately the Raptor drives are yesterday's technology, especially those old original Raptors. A current 7200RPM 500GB/platter drive will actually out-perform that old Raptor by a pretty large margin. The 500GB WD drive isn't a good idea either since it uses old technology 250GB/platters. I would just pick up a pair of these drives:
Seagate Barracuda 7200.12 ST3500418AS 500GB 7200 RPM 16MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive $54.99
Believe it or not, Intel brand motherboards are not very good. You're much better going with a board by either Gigabyte or Asus.
http://www.newegg.com/Product/Prod [...] rder=PRICE
or
http://www.newegg.com/Product/Prod [...] rchInDesc=
Reply to shortstuff_mt
Thanks for the help. So will 600w be enough power? Please review the changes so far, specifically the motherboard.
Reply to bcrosbie
For only one card, 600W is definitely enough.
That board is better. If you can afford it, this Gigabyte GA-P55A-UD3 has USB 3/SATA III ports, and is only about $25 more than the Asus.
Troubleshooting
Reply to MadAdmiral
600W is more than enough for a single GPU system. Even a quality 500W PSU is enough for that system.
Any other comments or thoughts? I am about to pull the trigger on this order and want to make sure I have everything in order.
Reply to bcrosbie
Make sure to check for combos. Other than that, it looks good to go.
Troubleshooting
Reply to MadAdmiral
Thanks for your help. Should I delete this thread or mark it [Solved] ?
Reply to bcrosbie
Mark it solved.
Troubleshooting
Reply to MadAdmiral
There are 1900 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
1200-1400 Gaming PC - Want Opinions
By Why_Me, 48 minutes ago:
The Z68 boards are older and targeted for Sandy Bridge cpu's. For the newer Ivy Bridge...
Best offers
Top experts
