Okay after a Long hiatus I decided to get back into Water cooling, I started in water cooling with an aquarium pump, homemade block and a heater core out of a Pinto I ended with Triple 8800 GTX rocking a HE 120.3 in push pull with Danger Den Blocks
This system will be a Thermaltake Overseer RX-I VN700M1W2N, i7-3770k on a Gigabyte Z77X UP5 MB
Been out of the game a while so I am rusty so I am going to start out with just the CPU I am hoping for a STABLE!! 4.2 to 4.5GHZ and the only noise I want to hear is the clicky clack of my keyboard.
The Case has room for Dual 200MM Fans but I can adapt to get the dual 120MM radiator installed looking for input on the options below, I know the H100I will not outperform the other stuff but if it will do the job its 100 bucks that can go towards other gear upgrades.
Black Ice Xtreme II Dual 120mm Radiator (Black)
XSPC Rasa High Performance Acetal CPU Liquid Cooling Block
XSPC X2O 750 Dual 5.25” Bay Reservoir Pump - Black Acetal Updated Version 4
VS
XSPC Raystorm 750 RX240 Extreme Universal CPU Water Cooling Kit (New Rev. 4 Pump Included) w/ Free Dead-Water!
VS
H100i
Total Budget for cooling is 200
VS
VS
H100i
