Computer Problems Please Help
I am new to the forums but have been working with computers my whole life. I am hoping that someone can help me with a problem that I have had with my computer recently. I am worried as that I have spent quite a bit of money on it and it is broken after only about 6 months, which is most likely my fault. I am going to try and describe everything that I think I might know about the problem, because I have almost no idea what the problem is. I bought a dell 540s studio slim recently and also bought a video card, being the idiot that I am, that was not a slim version. The video card is rated for a 300 watt power supply and as far as I know, mine is a 250 watt. After reading online, I assumed that it was ok to run the video card on my power supply, because after searching high and low, I could not find a small-atx power supply that was anything more than 250 watt. Also, I assumed that the worst that could happen is either the video card or power supply would break. It ran beautifully for about a week and one night I moved my computer so I took out the video card, and put everything back together. The next morning I came home, put the card back in and turned it on, and the problem that I am having now began then. When I turned it on, the power light was solid yellow, which I looked up and it means that the power supply is operrating properly, but the data communication is not. Any monitor hooked up to the computer goes directly to stand-by. After trying to run normally, the computer turns itself off, and then when the cpu fan completely stops, it turns itself back on, and slowly ramps the cpu fan up to full speed and then just sits there. I am assuming that this is just the computer attempting to fix itself, but I have no clue on this one. I am thinking that the problem is either in the motherboard or cpu. Any thoughts or ideas are greatly aprreciated.
Thanks in advance,
Patrick Hannigan
Information on components that I installed and thought may be useful.
Dell 540s/
power supply-model: PC7068
Motherboard-model:IPIEL-RN2
CPU-intel q8300 (2.5 ghz quad-core)
Hard Drive-seagate barracuda 7200.12 (500gb)
CD drive-hitachi-model:GH50N
Memory-corsair:XMS2-6400/CM2X2048-6400C5 (2gb/4=8gb total)
4 answers Last reply
More about computer problems help
  1. I tried running it without the video card, still the same problem. As I said, unless the diagnostics are incorrect, the power supply is supposedly operation properly.
  2. No, I do not know anyone with a micro-atx power supply. I do have a multi-meter that I can try to test it with.
  3. OK, thanks again for all the advice.
Homebuilt Power Supplies Graphics Cards Computer Systems
