Motherboard problem/issue search
  • Motherboards
  • Tom's Hardware
October 21, 2010 10:36:23 PM
Hi everyone at Tom's Hardware!
I would like to know if a motherboard alone in the case together with a ''mounted/connected'' power supply (turned on) is safe?
:??:  Q1 - Is it safe to turn on a motherboard (which have all power connections/connectors attached to it) without having no CPU, RAM, GPU
etc. connected while turning it on? Just to check if it's ''working/first test''?
Thanks in advance
/M9A2
More about : motherboard problem issue search
a c 232 V Motherboard
October 21, 2010 10:49:21 PM
While there is little chance that you will harm something, doing as you suggest will prove nothing. At a minimum, you need the CPU, memory, and GPU installed to see if the system is functioning. Good luck!
October 21, 2010 10:51:29 PM
Thanks mate!
/M9A2
a c 87 V Motherboard
October 22, 2010 1:34:01 PM
No harm done if it's not kept on a steel table or plate when you start it up :)
If you have nothing on it , I assumed you'll be starting it out of the case and not in it, so, no conducting material should be under the Mobo.... rest is all ok....
