Does anyone have any idea why my computer is having stability problems? Games like Far Cry 2 crash after a bit of play, usually about 10-15 min.
I have run Prime95. When running blend I have errors in 10 min. or less. I ran small FFT's for 2 hrs with no errors, so I think I can rule out my CPU.
I ran Memtest86+ on three different occasions each for 8+ passes. Only one out of the three did it find errors, and in only one test of one pass. No other errors. I read that Memtest is not always right so I disregarded the errors.
My specs:
CPU - i7 920
CPU cooler - Coolermaster V8 (idle - 38c, load - 63c)
RAM - OCZ Obsidian 1600 MHz (BIOS set up as OCZ suggests for RAM) 6GB (3x2GB)
Mobo - Asus P6T
PSU - OCZ ModxStream 700W
Graphic - Galaxy GTS 250
Case - Coolermaster HAF 932
Screen - AOC F22
HD - Seagate Barracuda 7200.11 1.5TB
Any suggestions would be helpful?
My specs:
CPU - i7 920
Mobo - Asus P6T
Screen - AOC F22
