Solved
My PC is dead, help!
So I was on my homebuilt PC, just doing what I normally do and then all of a sudden it shuts off. I thought, well okay it was a power outage, so I went to turn it back on and nothing happens, then I hear a pop and it smells like something is burning. I unplugged it, took it out and dismantled it(in the heat of the moment, I don't know why.) and I can't tell what died. So can anyone give me a clue what I can do to figure out which of the parts just died, I've been wanting to build a new system for a long time but I just don't have the money right now.
Thanks
7 answers Last reply Best Answer
More about dead help
  1. You heard a pop so it shouldnt be too hard to find what went wrong. Two likely sources of a pop, the motherboard or the PSU. Sniff the PSU if its what blew you should be able to smell it fairly clearly. Also take a look at the motherboard, if you see any bulging or burst capacitors they are the source of the problem.
    Can you post the specs of your system? Also do you have any other systems that you might be able to use a PSU from to check your main one?
  2. Wow, you're right the PSU smells burnt, I don't have any other PSUs to use though. My system specs
    Q6600 Quad core 2.4ghz CPU
    EVGA 8800GT 512mb
    2GB DDR2 Corsair RAM
    The PSU is just some cheap thing that came with the case, I think it's a 400watt.
    Everything else looks like it's in good condition, I don't see any bulges or burst parts on the Motherboard, the PSU definitely smells burnt though.
  3. Best answer
    Cheap PSU are usually a source of failure, hopefully it didnt kill anything else. Now would be a good time to invest in a good PSU that you can use in your future build, something with a 5 year warranty you can use when you make a build later.
    Normally i would suggest the corsair 550VX but its price shot up recently and its now almost as expensive as most 750W units. Are you only ever planning on running a single card in the rig you plan to build? If you want the option to run two cards down the line you might want something like the 750TX or TP-750
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817139006&Tpk=750tx
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817371022&cm_re=TP-750-_-17-371-022-_-Product
  4. awww that is one of the things i always tell people not to do...
    never use the stock psu that came with the case! allways get a new one... for your specs i would suggest 500+ watts at least. I would go with 650+ for upgrade capability! This is the one I have
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817153109&cm_re=evo_blue-_-17-153-109-_-Product
    although corsair and ocz have decent power supplies as well
  5. The corsair 750w seems fine, thanks for the help guys.
  6. Best answer selected by bishop113.
Homebuilt Systems Product
