Hi I'm new to the form/watercooling so I'm looking for advice about my parts list, feel free to tell me about better parts/cheaper but same ability but please tell me why you think your part/parts are better.
My computer as of now is as fallows.
Case: Corsair 800D
CPU: i7-2600k OC to 4 now will OC more when I'm liquid cooling.
GPU: evga GTX 460 v2 x2 not going to water cool these but am looking to upgrade in less then a year so i need a loop that can handle that.
PSU: Corsair AX860
Motherboard: Asus P8Z68 Deluxe/Gen3
Ram: G.Skill 12gb 3x4gb ddr3 1600
The parts I'm looking at getting are as fallows.
Reservoir: http://www.frozencpu.com/products/10277/ex-res-164/FrozenQ_PC_Mods_250mm_Liquid_Fusion_V_Series_2nd_Generation_Reservoir_-_UV_Cathode_-_UV_Blue_Helix.html?tl=g30c97s1110
Radiator: http://www.frozencpu.com/products/5326/ex-rad-109/Black_Ice_GTX_Xtreme_360_Radiator_-_Black.html
Fittings:http://www.frozencpu.com/products/11110/ex-tub-703/Bitspower_Matte_Black_Ultimate_G_14_Thread_12_ID_x_34_OD_Rotary_Compression_Fitting_BP-MBRCPF-CC5.html?tl=g30c409s1609 x6 i think 6 is all i will need.
CPU block: http://www.frozencpu.com/products/14365/ex-blc-1000/Swiftech_Apogee_HD_High_Performance_4-Port_CPU_Waterblock_-_Black_-_Intel_w_LGA_2011_Hardware_AMD_Ready_Apogee-HD-BK.html?tl=g30c85s139
Pump: http://www.swiftech.com/mcp655.aspx
Tubing: http://www.frozencpu.com/products/13728/ex-tub-986/Danger_Den_DreamFlex_Value_Pack_-_Tubing_Clamps_Tube_Cutter_12ID_x_34OD_-_UV_Blue.html
I'm not sure what the best coolant is i know i don't want to use distilled water but thats all so post your favorite.
P.s I'm only 16 so i don't have a a million dollars to spend on parts this is going to take me a good while to save for as is so please don't go over the top with expensive parts unless they are 100% better then i have posted here.
Case: Corsair 800D
PSU: Corsair AX860
