Hi guys,
I currently have one desktop machine connected straight into a Time Warner Cable 15 Mbps internet connection, no routers and nothing in between. Just the computer, ethernet jack and cable modem into my wall. Everything is great and I get great ping for gaming.
However I need to move my desktop to the corner of a wall which will necessitate routing the cable over walls and door frames. I don't want to do this and so I'm looking into wireless.
I need to buy a wireless N router (looking into the Linksys Cisco brand) and a wireless N USB adapter for my desktop computer. My question is: which is the VERY BEST router+adapter combination that will give me pure, unhindered internet connection in both bandwidth and ping? I basically want to go wireless and feel like I'm still on a hardline connection. The distance from the computer to the router will be no more than 6 feet away, in the same room.
Please help me! Are the linksys Cisco routers any good? Should I get the dual band ones?
