Taking the Plunge into Water Cooling - Seeking Advice!
I just got done reading through this stickied post amongst some other quick-start guides:
http://www.tomshardware.com/forum/277130-29-read-first-watercooling-sticky
That said, I still am feeling a little bit uneasy on where to start.
I could go about making an educated decision on buying anall in one internal water cooling kit, but I've had friends tell me that it's better to buy the parts individually.
I'm half doing this to lower temps and also half just for the experience (got some extra money laying around time to enlighten myself!)
These are my comp specs:
CPU: Intel Core i7-920 2.66Ghz 8M LGA1366 CPU
GPU: EVGA GTX 260 Super Clocked -> Upgrading to MSI GTX 680 Lightning in 2 days
PSU: ULTRA X4 750W POWER SUPPLY MODULAR
RAM: Corsair XMS3 6GB DDR3 Tri PC12800 1600MHz (3x2GB)
HDD: WD Caviar Green 1TB 32MB/SATA-3G -> "Upgrading" to Samsung SSD 840 Pro
MOBO: Asus P6T Intel X58 Socket LGA1366 Motherboard
OTHER: LG 22X DVDRW SATA w/o Software
CASE: CoolerMaster CM690 Black ATX Case SLI Ready
My goal is to have a water block for the CPU & GPU.
Budget = no real budget, but was hoping to stay in the $200-400 range.
Can anyone give me a nudge in the right direction?
I'm guessing my shopping list has to include:
1. Radiator: ???
2. Fans: ???
3. CPU Blocks: ???
4. GPU Block: ??? (This one seems easy, there appears to be a specific block for the MSI GTX 680)
5. Pumps: ???
6. Res: ???
7. Tubings & Fittings: ???
*Edit: Included Case (Note: I would consider buying a new case if need be)
4 answers Last reply
More about taking plunge water cooling seeking advice
  1. What case are you using?
  2. CASE: CoolerMaster CM690 Black ATX Case SLI Ready
    Haven't added anything additional in terms of fans or anything atm.
  3. Listing close to this as i am about to do the same, altough my hardware to be cooled is the i7 2600 and Radeon HD 7970.
    GPU cooler:
    Alphacool NexXxos ATXP Full Cover Waterblock ATI 7970 & 7950 Graphics Card : Brushed Copper
    GPU Backplate:
    Alphacool NexXxoS ATXP AMD/ATI 7970/50 Backplate
    CPU cooler:
    Alphacool NexXxos XP3 Light Universal CPU Waterblock : 12153
    Pump:
    Alphacool TPP644 Laing D4 Fixed Speed 12V Pump : VPP644
    Radiator:
    Alphacool NexXxoS ST30 240mm Dual Radiator : Full Copper
    Reservior:
    Alphacool 5.25" Repack Single Bayres : Clear
  4. 690, not 690 II right?
Water Cooling Overclocking
