Hey got a problem here( think im in the right category, hoping for quick answers
as you see here the power cable ends with 2 ends 4pin plugged in the motherboard and 8pin i want in the graphic card and the 4pin part is plugged in the motherboard which makes the other end too short since it needs to reach
Just open the pictures so you see better
the graphic card is a hd 4890 looks like it needs two 6pin power cables but i read it needs 1, 6pin and a 8pin
my question is if i should get a lengthener if it exsists 8pin to 8pin or get a 8pin to 6pin and if the graphic card gets enough power if the cable is also connected to the motherboard
ok hope i was clear enough so people understood this
