Solved
Are these parts compatible
Before I purchase I just want to make sure these parts are compatible, thanks.
http://www.newegg.com/Product/ComboBundleDetails.aspx?ItemList=Combo.343620
5 answers Last reply Best Answer
More about parts compatible
  1. Best answer
    I do not think newegg would put them in a 'SuperCombo' if they where not...
    Yes, everything will work together.
  2. Best answer selected by johnjohnson.
    Thank you, I am a newbie and just wanted to make sure seeing as how under policies new egg says "we
    cannot guarantee that combo items are compatible".
  4. No problem, it is always good to check if you are not sure.
    Come to think of it, I do remember newegg bundeling an AM3 CPU with a LGA1156 motherboard a few months back :lol:
    By all means........ never trust somebody else to put something together for you..... e-tailers. They make many mistakes.
New Build Compatibility Systems Product
