System specs:
mobo - GA-z77x-UD5H
CPU - I7 3770k
memory - 16gb of corsair XMS3 1600 mhz
gpu - radeon 7950
case - cool master storm trooper case w/ a corsair H80 Liquid cpu cooler,
problem is at default cpu/mobo settings my cpu runs between 70-73 celsius according to cpu temp, when i over clock to even just 4.0 when i use AIDA 64 for stress testing it my cpu runs in the mid 80s (im under the imprssion you shouldnt let your cpu run consistantly above 75 degrees,.. why is this happening? what should i do? I should mention im a new to OCing but from what I read this board and cpu are both friendly to over clocking, anyhow Id appreciate any help,
Thanks
mobo - GA-z77x-UD5H
CPU - I7 3770k
gpu - radeon 7950
Thanks
