G
Guest
Guest
I am wondering if this sounds like a blown CPU or motherboaboarrd.
My friend gave me his computer to try and fix and its a BIOSTAR TF570 SLI MB with an athlon processor. He said it worked good before, but now it does not boot up. It powers up, fans run, USB power works, but no POST. The indicator on the MB says that it is a CPU/Abnormal problem (there is four lights instead of beeps).
I tried everything, and ruled out the RAM, PSU, and Video Card. I did everything unhooking the peripherals and resetting the CMOS as well as reseating the CPU.
I am experienced in working with computers, except I never dealt with blown hardware (if that is the case). No matter what you guys say, the PSU is NOT the problem. It was tested and used on another computer, as well as the RAM and video card.
There is no burn marks or smells eminating from the the system, and I am wondering what part is kaputt.
Thanks
Thanks
