Closed Solved
[water cooling help] water block compatibility
ok i'm water cooling a rig i just built for myself and i went on EK's website and went through the configurator. it said for my gtx 660 ti's (evga FTW 2 gig signature) a gtx 680 water block would work. is this true or should i try another website?
3 answers Last reply Best Answer
More about water cooling help water block compatibility
  1. Best answer
    have you searched e-tailers?
    from what's available, The GTX 660Ti utilizes the same PCB of a GTX 670, however, this bit of info should be taken with a teaspoon of salt as there's always bound to be PCB revisions, re-revisions by manufacturers or board makers.
    That said:
    http://www.frozencpu.com/search.html?mv_profile=keyword_search&mv_session_id=pAmtnevL&searchspec=GTX+660Ti&go.x=0&go.y=0
    http://www.frozencpu.com/cat/l3/g30/c311/s1708/list/p1/Liquid_Cooling-Water_Blocks_VGA_-_Card_-_nVidia-GTX_670_Water_Blocks-Page1.html
    * the GTX680 has a longer PCB if you're curious.
  2. Best answer selected by slendermanFTW.
  3. This topic has been closed by Rubix_1011
Water Cooling Gtx Compatibility Overclocking
