Hello you water cooling Gods!!, As the thread title says, I'm looking for some answers as to how many GPM/LPM a pump in a water cooling loop requires for optimum cooling performance and some suggestions on which pumps, (off the top of your heads to help narrow down the search), that can pull that off with the radiators I am thinking of using. This is the beginning of the work in progress so accompanying links for research are GREATLY appreciated. I haven't purchased any new water cooling equipment for this build yet but I do have some laying around. I've done some water cooling in the past but it really didn't perform to well and I really don't much care for and have tried the prebuilt systems that just don't quite give me the performance I'd like, so, here I am, ready to learn and do. I did just purchase an AZZA Fusion 4000 and I am looking to set up a nice water cooling unit. I will only start with the cpu cooling, but I want to build the Rad/Pump/Res setup to be able to add the GPU and memory at a later date. Funds of course.
I'm am looking at the TFC X changer 480 and 360 rads. I will be using both of them in the loop and I like the lower fin count so I don't have an airplane next to me while it's running.
So, this being in the "seeking an answer section", the question is - with those rads running in series, what pump will give me the 1.0 to 1.5 GPM , (which I think is the recommended flow rate), Or do you need all the components/blocks before you can actually answer that question?
Thanks in advance for you help.
