G
Guest
Guest
Hello,I have a AMD x4 phenom 965 with its stock cooler installed.
Before I would get 37-38C idle temps and when playing games etc it would go up to around 45-50C.
But these past 2 days when I play games the temps increases to 60-61C straight away. If it was a dust/airflow problem than wouldn't the idle temps change aswell, the idle temps are still 37-38C.
The games themselves seem to be running at higher rates aswell. Before it was 30-40% but now its 100%. I haven't done anything different (that I can remember anyway)
Thanks
Additional info:
Motherboard: Gigabyte GA-MA770t-UD3
GPU: Sapphire 5850 1GB
RAM: 4GB
Thanks
Additional info:
RAM: 4GB
