I'm having some issues with my xfx hd 4850, which is more than likely directly because of how it's being powered. Due to not having a spare 6 pin, I'm using the (6pin to 2 4pin) adapter that came with the box. However, my BFG 550w psu, and how its supplemental power is distributed, only has the 4pins on a supplemental power circuit, which is the HDD hookup, a 4pin, and another 4pin on a single power line. I have each of these 4 pins in that series hooked up to the (6pin to 2 4pin) adapter. So to sum that up, I have a single supplemental power cord (all others are used) attached to 1. hard drive, 2. a 4pin from the 4850 adapter, 3. a 4pin from the 4850 adapter. Yell at me and tell me what I'm doing wrong here....I'm a bit tied with my PSU's adapter availability, but is this thing getting enough power (another thing is that I have no clue how to crossfire, are both these 4pins supposed to be used as I am using them, or will one suffice for power?).
My symptoms are pixellating and crashing my system, requiring removal of power to restart than having to mess with resolution. This happens during Heroes IV and google earth....so I'm thinking I'm not exactly taxing it.
I'm packing a i5-750 with 8gb 1333 ram. 550w psu.
