APPROXIMATE PURCHASE DATE: 2 Weeks
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: Gaming
PARTS NOT REQUIRED: Keyboard, Mouse, Monitor, Speakers, OS
PREFERRED WEBSITE(S) FOR PARTS: newegg
PARTS PREFERENCES:
OVERCLOCKING: Yes
SLI OR CROSSFIRE: Yes - Eventually want to get another 5770
MONITOR RESOLUTION: 1680x1050
ADDITIONAL COMMENTS: So I have read a few comments on the forums about the 1156 socket possibly running into longevity issues... so not sure if I should think about doing a 1366 i7? Would an AM3 socket run into this issue too?
I have a $1000 max budget before rebates.
Any help is greatly appreciated.
Will be running Windows 7 64-bit
Case : Xigmatek MIDGARD-W Black 0.7mm SECC ATX Mid Tower Computer Case - Retail - $74.99
HDD: Western Digital Caviar Black WD5001AALS 500GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive - $69.99
Mobo: GIGABYTE GA-P55A-UD3 LGA 1156 Intel P55 SATA 6Gb/s USB 3.0 ATX Intel Motherboard - Retail - $134.99
Video Card: SAPPHIRE 100283L Radeon HD 5770 (Juniper XT) 1GB 128-bit GDDR5 PCI Express 2.0 x16 HDCP Ready - $159.99
PSU: CORSAIR CMPSU-750TX 750W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 Power ... - Retail - $109.99
CPU - Intel Core i5-750 Lynnfield 2.66GHz LGA 1156 95W Quad-Core Processor Model BX80605I5750 - Retail - $199.99
RAM: G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-4GBRL - Retail - $104.99
Optical - LITE-ON CD/DVD Burner - Bulk Black SATA Model iHAS124-04 - OEM $26.99
HSF: COOLER MASTER Hyper 212 Plus Intel Core i5 & Intel Core i7 compatible RR-B10-212P-G1 120mm "heatpipe direct contact" Long ... - Retail - $34.99
Total is about $926.00 before shipping.
PARTS PREFERENCES:
OVERCLOCKING: Yes
