I'm thinking about either buying a pre-built system(probably Dell) or building my own. I want to support 3-4 monitors, preferrably 4. The computer will be used as an entertainment center(1080P video on large screens) as well as for work(excel VBA, some photoshop, having a ton of web pages open). I will have the computer hooked up to my TV(HD 34" CRT with HDMI ports), 2 new monitors(19") that I will buy and already have an old 17" Dell LCD Monitor. I will probably buy a large HDTV in the near future(hopefully with a DVI port) to replace the CRT.
I'm having a problem with what graphics card(s) to buy and how they should be setup with the motherboard. If there is anything you would like to recommend(Types of CPUs, ram, etc.. I have looked at the bolded links at the top of the page) let me know as it's been awhile for me. My budget is in the $700-$1300 range. I know it's a wide range. I would preferrably like to keep it around $1000 so I can start buying some new monitors.
Thanks,
Matt
Thanks,
Matt
