Is this ok to do EDIT: I think I figured out my problem =( It's bad
Last response: in Systems
- Worried about Overclocking a i5-3570K and I think I've almost got it figured out. - Forum
- Think I've Got It Figured Out, But Need Opinions - Forum
- I think I finally figured out why my Samsung 840 (EVO) SSD locks into a frozen state (including enhanced instructions for fix) - Forum
- Wierd Canopus Let's Edit Bug Figured Out - Forum
- Suspect a bad PSU or mobo or both. Desperate to figure out problem. - Forum
- figured out the problem. Forum
- Think I Figured Out My Build, Comments and Suggestions Please Forum
- SolvedGetting very consistent and bad FPS drops in ALL games. I cannot figure it out. Forum
- SolvedDo you guys think this is a good build overall? OS good? Also does motherboard have USB 3.0 ports? Can't figure it out. Forum
- Solvedcan't figure out where my GPU power adapter (I think it is, anyway) goes Forum
- Solvedok i'm trying to figure out what one of these is better. (replacing old q6600) Forum
- SolvedDVI-D/HDMI 2nd monitor flickers, bad quality - can't figure it out! (VGA works fine) Forum
- How do I figure out if I have a bad card? Ran GPU Shark program - how interpret? Forum
- I screwed up my sound, I think and can't figure out how to fix it. Forum
- SolvedNeed a little help in figuring out if the pc i'm going to buy is ok Forum
- SolvedSpilled on my tower, issues figuring out which parts bad. Forum
- Finally figured out my wireless problems. Forum
- Cant figure out if bad psu or not? Forum
- SolvedThinking of building a PC for gamining and need help figuring out what I should get (starting from scratch) Forum
- SolvedI cant figure out this problem with my computer. Forum
- More resources
I need to read more about it, I suppose.
