So I'm thinking of upgrading my computer parts.
This is the tower I have. The picture isn't exactly the same as the one I have (the symbol is up higher. Whatever though.) For all intents and purposes though, this is the tower I have.
http://di1-3.shoppingshadow.com/images/pi/7a/69/f9/107792905-260x260-0-0_systemax+syx+venture+sbe1+desktop.jpg
I currently have a Pentium Dual-Core E6700 3.2ghz which came stock with the tower. I want to upgrade to a Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) and I want to try and overclock it to 4.0 or 'maybe' higher. It will be the first time I've overclocked, but I've read a lot on it, and I intend to read more to make sure I do it right.
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072
Doing this means I will also have to upgrade my MOBO and my PSU, so these are the options I was thinking of..
FOR MOBO
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131806&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&AID=10446076&PID=4176827&SID=y4y3f6apor36
or
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157303
or
http://www.newegg.com/Product/Product.aspx?Item=N82E16813138345
Those are my 3 (sort of) ideas for the MOBO. I'm going mATX because of the small amount of space I have to work with, and I don't really want to have to buy a new tower if I don't have to.
PSU's
http://www.newegg.com/Product/Product.aspx?Item=N82E16817341017 (Not sure what other's. Not really sure about PSU's at all. Help on that?)
And I'll finally need a heatsink for the overclocking. I'd rather not go water cooled because I don't want to have to deal with the maintenance. So I found the COOLER MASTER Hyper 212 Plus, which seemed to come highly recommended. The Thermaltake Frio was also highly recommended, so that's an option too.
I should mention that I currently run a EVGA GTX 550 Ti for my GPU.
What I'd like to know, is what you all think of that build for an upgrade. I'd also like what you think might work better for similar pricing, or what I could change (What I'm doing wrong). General feedback is welcome.
Like I said, this is the first time I'm doing something like this (overclocking and such) so I would appreciate all the help I can get.
Thanks.
-Alec
FOR MOBO
or
or
PSU's
Thanks.
-Alec
