BEST GRAPHICS CARD FOR A 600 WATT POWER SUPPLY
Hello
Hi. I have a Dual Nvidia GTS 240 (1GB each)system and was thinking of doing a upgrade on this graphics config, and was wondering what should I go with?..Does a single GTX 260 Core 216 have better performance than my current set-up or maybe the 275. Your Thoughts? Thanks
8 answers Last reply
More about best graphics card watt power supply
  1. Did those come in a dell? because stock GT 240s arent SLI capable... Considering they are nonstandard dell cards I cant give you any benchmark comparisons...
    What is your price range, system specs, screen resolution, and purchase date?
    You display a very large range here... a GTX 260 is worth about $165 and a GTX 275 goes for $350...
    Personally I would suggest you not go with a Nvidia option--as ATI cards are newer technology right now. Most likely your best bet is to wait a week or two and get an ATI 5830 for $200-250, or to just go ahead and get a 5850 right now for $300.
  2. Well sort of, I recently bought a Alienware and it came in a Dual GTS 240 1gb setup. Ya I know, most people hate Alienware, but I didnt have the tech savvy or the time to do it myself and I thought it was a good deal. Hers what I know offhand about my system.
    Alienware Aurora X58 920 OC to 3.2 gb
    620 (320x2) RAID-0 GB harddrive
    650w PSU
    Nvidia GTS-240 1Gb Graphics
  3. I forgot to note that pretty much any single card would be fine if that's a Dell 600w PSU. The fact that you had 2 cards means they had to put in something decent.
  4. Well if you can afford it a 5850 would dominate basically every game possible, even at high resolutions.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814161302&cm_re=5850-_-14-161-302-_-Product
  5. Ok, Im not real worried about the cost. I just want the best Graphics that I can run with the system I currently have without making a PSU change. Does the 5870 have better performance than the Dual GTS 240s?
  6. Yes, it has much much better performance than your two 240s. Get a 5870, game, be happy.
  7. Thanks for the info and help guys. This is the best damn tech website I have ever been on. Im glad my friend recommended it.
  8. Most cards above $145ish has better performance than your GTS 240s.
    Either a 5850 or 5870 would be many times more powerful. However, unless you are running a few very large monitors I highly doubt you will be able to tell the difference between the two--so I would suggest you save the $100 and go with the 5850.
    Toms declares the 5850 "Exceptional 1920x1200 performance, 2560x1600 in most titles" and the 5870 'Good 2560x1600 performance in most games"
Graphics Cards Power Supplies Graphics Product
