An odd problem. Power on, auto resets, and stays on with no response.
My problem is I built a new computer. After finally getting a new case (the one I bought came to me dead on arrival), my computer will turn on, and after two seconds, turn off, and then a second later, turn on again by itself. After it turns back on I get no response out of it. No beep code, no video, no audio, nothing. It just stays there on by itself.
1 answer Last reply
More about problem power auto resets stays response
  1. Are you sure you have your case headers connected properly? Double check those first, sounds like you may have the wrong configuration. Check your mobo's manual and make sure you have everything hooked up correctly.
New Build Computer Power Systems
