Problem with pump on Zalman LQ320 cooler
Hi, I just installed the Zalman LQ 320 and the pump does not seem to be turning on. I'm pretty sure its this because the blue led that is supposed to be on with the pump is not on either and the CPU hits 50 at start and rises about 5 degrees every 15 seconds. Rest of the computer is running fine and the fan on the rad is running fine.
Did I miss something?
Thanks in advance ^^
2 answers Last reply
More about problem pump zalman lq320 cooler
  1. Quote:
    Did you get this resolved?
    There are two power connections for that cooler. I assume that you have both attached.
    The fan goes on CPU fan header and the pump to case fan header.
  2. This topic has been moved from the section CPU & Components to section Overclocking by Mousemonkey
Water Cooling Zalman Cooling Overclocking
