Is water cooling the way to go for my rig?
Im interested in buying a good gaming rig i have done some research but i cant decide if i should get water cooling or air everyone seems to have a different opinion but with the following specs which is the better way to go?
Money isn't really an issue.
Intel Core i5 3570K Unlocked Quad Core Processor| ASUS Sabertooth Z77| GeForce GTX 670 2GB| Cooler Master Silent Pro 700w|
Corsair Vengeance Blue Lowprofile 8GB
More about : water cooling rig
will you be putting it together?
are you confident about it?
its most certainly the best way to go as far as noise, temps, and looks are concerned.
but is it worth the time, money, and effort you'll need to put into it.
really these questions are best answered by YOU....
No im ordering it from NCIX my friends have recommended it and both their systems were assembled well and i am confident that it will last and put out but i have heard sometimes water cooling can leak and cause problems and i definitely dont want that happening. Is this a real risk or is it a one in a million?
