Archived from groups: microsoft.public.windowsxp.configuration_manage,microsoft.public.windowsxp.help_and_support (More info?)
Selecting a file/folder with the right mouse button, for dragging no longer
works (in my XP-SP2) Rather than selecting the file or folder to be dragged,
the right mouse button now always immediately opens the right-click menu,
whereafter dragging the file or folder becomes impossible. Are there some XP
tweakings I can do to restore the standard right-click "select and drag"
function, (without turning off the right click menu feature, that's very
handy
too, and I'd hate to lose it)?
Trond Ruud
Use left click to Select.
select
[[To specify a block of data or text on screen by highlighting it or
otherwise marking it, with the intent of performing some operation on it.]]
Hope this helps. Let us know.
Wes
In news:u7SOv7xzEHA.1264@TK2MSFTNGP12.phx.gbl,
Trond Ruud <truud2@netscape.net> hunted and pecked:
> longer works (in my XP-SP2) Rather than selecting the file or folder
> to be dragged, the right mouse button now always immediately opens
> the right-click menu, whereafter dragging the file or folder becomes
> impossible. Are there some XP tweakings I can do to restore the
> standard right-click "select and drag" function, (without turning off
> the right click menu feature, that's very handy
> Trond Ruud
Sorry, I should have been more specific. The left-click 'select and drag'
works fine.
My problem is with zip files. I've usually right-click selected the .zip
file and dragged it to the folder that I want to unzip it to. Previously,
when I right-click selected and dragged a zip file over the target folder I
got a Winzip menu prompting to unzip to that folder. If I drag the zip file
to the folder with a left click select, the Winzip menu doesn't display and
the zip file is moved into the folder instead, which is rarely what I intend
to do, and the right-click select and drag doesn't work as before, like I
described originally.
Trond Ruud
In news message0yYepzzEHA.3120@TK2MSFTNGP12.phx.gbl,
Wesley Vogel <123WVogel955@comcast.net> wrote this:
> select
> it.]]
>> Trond Ruud
There are a slew of registry entries for ...DragDropHandlers\WinZip
Have you unregistered zipfldr.dll & cabview.dll ?
Start | Run | Type: regsvr32 /u zipfldr.dll | OK
Start | Run | Type: regsvr32 /u cabview.dll | OK
Reboot.
Instead of wasting time checking registry entries, maybe uninstall and
reinstall WinZip?
Wes
In news6HdrrA0EHA.2316@TK2MSFTNGP15.phx.gbl,
> drag' works fine.
> .zip file and dragged it to the folder that I want to unzip it to.
> Previously, when I right-click selected and dragged a zip file over
> the target folder I got a Winzip menu prompting to unzip to that
> folder. If I drag the zip file to the folder with a left click
> select, the Winzip menu doesn't display and the zip file is moved
> into the folder instead, which is rarely what I intend to do, and the
> right-click select and drag doesn't work as before, like I described
> originally.
> Trond Ruud
>> select
>> it.]]
>>> off the right click menu feature, that's very handy
>>> Trond Ruud
Hi Wes,
You seem to be on to something, since after uninstalling an re-installing
winzip I succeeded in doing a right-click select of zip files and drag them
to a target folder (with the winzip menu displayed over the target), in 2
out of 3 attempts, and if I can keep up that rate of success, I'll consider
the problem solved.
Thanks!
Trond
In news message:%23FfHRpC0EHA.3076@TK2MSFTNGP10.phx.gbl,
> Trond,
> I did misunderstand your original post.
> Could WinZip be corrupt?
> Could be something be funky in the registry because of that?
> WinZip ClassID = {E0D79305-84BE-11CE-9641-444553540000}
> Reboot.
> reinstall WinZip?
>> drag' works fine.
>> originally.
>> Trond Ruud
>>> select
>>> on it.]]
>>>> no longer works (in my XP-SP2) Rather than selecting the file or
>>>> folder to be dragged, the right mouse button now always
>>>> immediately opens the right-click menu, whereafter dragging the
>>>> file or folder becomes impossible. Are there some XP tweakings I
>>>> that's very handy
>>>> Trond Ruud
Howdy Trond,
You betcha! Keep having fun! :-)
Wes
In news:ups$nfK0EHA.3236@TK2MSFTNGP15.phx.gbl,
> Hi Wes,
> re-installing winzip I succeeded in doing a right-click select of zip
> files and drag them to a target folder (with the winzip menu
> displayed over the target), in 2 out of 3 attempts, and if I can keep
> up that rate of success, I'll consider the problem solved.
> Thanks!
> Trond
>> Trond,
>> Reboot.
>> and reinstall WinZip?
>>> drag' works fine.
>>> Trond Ruud
>>>> select
>>>> or otherwise marking it, with the intent of performing some
>>>> operation on it.]]
>>>>> that's very handy
>>>>> Trond Ruud
