a pc used to convert video's and for rendering models. also some gaming
APPROXIMATE PURCHASE DATE: april 10 2010
BUDGET RANGE:$1000-1200
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: rendering and video editing
PREFERRED WEBSITE(S) FOR PARTS: newegg!!
COUNTRY OF ORIGIN: philippines
PARTS PREFERENCES: just not foxcon or asrock
OVERCLOCKING: maybe
SLI OR CROSSFIRE: crossfire in the future
MONITOR RESOLUTION: anything
something i came up with.
ARCTIC COOLING Freezer 7 Pro Rev.2 92mm Fluid Dynamic CPU Cooler - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16835186134
Intel Core i7-920 Bloomfield 2.66GHz 4 x 256KB L2 Cache 8MB L3 Cache LGA 1366 130W Quad-Core Processor - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115202
Rosewill DESTROYER Black Gaming ATX Mid Tower Computer Case ,comes with Three Fans-1x Front Blue LED 120mm Fan, 1x Top 120mm Fan, 1x Rear 120mm Fan, option Fans-2x Side 120mm Fan,1x Top 120mm Fan,1x Bottom Fan - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147144
LITE-ON Black 24X DVD+R 8X DVD+RW 24X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM SATA DVD/CD Writer LightScribe Support - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106332
Western Digital Caviar Black WD1001FALS 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136284
CORSAIR XMS3 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMX4GX3M2A1600C9 - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145260
SAPPHIRE 100283L Radeon HD 5770 (Juniper XT) 1GB 128-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFireX Support Video Card - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102858
OCZ ModXStream Pro OCZ600MXSP 600W ATX12V V2.2 / EPS12V SLI Certified CrossFire Ready 80 PLUS Certified Modular Active PFC Power Supply compatible with core i7 - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16817341017
GIGABYTE GA-X58A-UD3R LGA 1366 Intel X58 SATA 6Gb/s USB 3.0 ATX Intel Motherboard - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128423
OVERCLOCKING: maybe
