Laptop issues, please help
I am having laptop issues. My notebook laptop usually works well but today when i turned it on something went wrong. When i turn it on it starts with the Microsoft Windows XP startup then a light blue screen comes up that says
Check file system on C:
The type of file system is NTFS
One of your disks needs to be checked for consistency. You may cancel the disk check, but it is strongly recommended that you continue.
I usually click any button and it goes away but after it said "Windows is setting up" it cut to a dark blue screen with white writting but it went off too fast for me to get a good luck and then it goes right back to the Microsoft Windows XP startup...I am not good with laptop and I have no clue what I am doing so can someone PLEASE PLEASE PLEASE help me. My laptop contains much important school work and irreplacable things. please hel
2 answers Last reply
More about laptop issues help
  1. Did you connect and external device or update windows ?
    Let it go through with the check first.
    it's doing a error check cause it needs it nothing wrong it's trying to fix itself so let it. it's cause it lost the boot order & needs to check for it ;)
Configuration Laptops File System Blue Screen Windows XP
