I purchased the larkooler isky 300 water cooling kit yesterday and when i was done setting it up i powered on my pc to see my temps it was at a 60c idle and i thought that cant be right so i restarted and the temps were the same. i had about 3 fans plugged into the 4 pin connecter i was using for the cooler because all the others had messed up pins so i fixed the pins on another connecter for the pump thinking that it was drawing to much power from one connection and when i powered it on it was running at 13c idle keep in mind this is a cheap cooling kit like 120$ cheap so that couldnt be right i checked other programs besides coretemp and all read the same. Is my sensor fried?
Thanks
Thanks
