I'm currently planning out all the components for my new gaming rig. I'm quite certain I have worked out most of the key components for my build as follows:
Case - Azza Genesis 9000 (Black)
Motherboard - Asus Z77 Sabertooth
CPU - Intel i5-3570k
GPU - MSI HD7970 OC (R7970-2PMD3GD5/OC)
RAM - Corsair Vengeance 32GB (4 x 8GB) 1866 MHz (CMZ32GX3M4A1866C9)
PSU - Corsair AX850
Monitor - Asus PB278Q 27" LED 2560x1440
The SSD, HDD, ODD, Keyboard, Mouse, etc don't really matter at this point since this topic is about water cooling components.
I've been looking at using the XSPC Raystorm Extreme Universal CPU Water Cooling Kit w/ RX360 Rev 2 Radiator/D5 Pump/Res
Kit includes:
Raystorm CPU Waterblock
Socket 2011, 1366 and 1156(1155, 775 Backplates)
Socket AM2 and AM3 Block Optional
XSPC Dual 5.25" Bay Reservoir - w/ D5 Vario Pump
5mm Blue LED with 4Pin Molex
RX360 Radiator
Low Noise 120mm Fan x 3
120mm Fan Grill x 3
2M (6.5')' of Tubing, choice of colors/size
Compression Fittings x 6 choice of size/color
Thermal Paste
For CPU only, this kit would be overkill, but I'll be using it for both CPU & GPU. I've been looking at a few options for GPU waterblocks & have my eye on 2 options by Swiftech & 1 by XSPC.
Swiftech MCW82-7900 with 7970-HS (most likely with a SP120 fan on the HS)
or
Swiftech KOMODO-HD7970
or
XSPC Razor 7970 (New)
The cost difference between those options isn't a concern of mine. I'm concerned about cooling performance and compatibility with the rest of the water cooling loop/kit. Any opinions, suggestions, feedback would be appreciated.
Another thing that's been racking my brain is how to setup a drain in this layout. For fill, I'll be using a rotary 90 with a short tube connecting to a fill port coming right off the res, which will be tucked behind a removable 5.25" front panel. For an example of this, check out this video http://www.youtube.com/watch?v=cseLyQzK_7I @ about 3:15.
PSU - Corsair AX850
Kit includes:
RX360 Radiator
120mm Fan Grill x 3
Thermal Paste
or
or
