Best kits for water cooling?
There is a list of beginner kits in the watercooling sticky:
Sticky:
http://www.tomshardware.com/forum/277130-29-read-first-watercooling-sticky
List:
http://www.tomshardware.com/forum/277130-29-read-first-watercooling-sticky#t1992132
You will also need the GPU block, addition tubing and fittings. You will also need to calculate the radiator space needed when including a GPU to determine if you need to add more or alter your initial component selection.
Of course, you can simply build a loop with the components you wish.
