Best cooling solution, need advice
Hi,
A few months ago I built a mid range PC for gaming. It has performed extremely well and I'm very impressed with its quality. However, one issue I have is cooling. I am using the stock case fans and heatsink pictured below, which results in the CPU reaching 30 degrees idle and ~62 degrees full load. Are these temperatures okay? My specs are below.
CiT Vantage Type R Case with its four unbranded stock case fans (http://tinyurl.com/at7qpg2)
AMD Phenom 965BE @ 3.6GHz (1.375V stable)
Gigabyte HD7850 2GB Windforce @1GHz
8GB Vengeance Low Profile RAM
500W OCZ PSU
These are the side fans:
The heatsink:
And the exhaust/space in case:
I'm looking for a budget option for cooling temps down to below 60 degrees load, happy to spend about £30 on coolers/fans. I'm unsure of whether it is the airflow in the case or the cooler itself (which doesn't seem to do that much of a bad job). If I were to look at coolers, what could I fit in my case judging by the photos? A Hyper212 EVO seems far too big for the width of the case.
Some options I've looked at so far:
Replace both side panel intake fans with Aerocool Sharks (£10 each)
Replace side panel AND exhaust fans with Aerocool Sharks (or comparable fans in the same price range)
Replace CPU cooler with something like a Hyper 212 or A30
Which of these options would be most effective/plausible?
Thanks in advance
3 answers Last reply
More about best cooling solution advice
  1. I'd give odds that the Hyper212 EVO will fit your case (just barely) but, another viable option from Cooler Master might be the GeminII SF524 http://www.scan.co.uk/products/cooler-master-geminii-sf524-cpu-cooler-5x-heatpipe-with-120mm-silent-fan-supports-intel-and-amd-cpus which is a very good low profile cooler.
    I'd suggest replacing the stock HSF before adding more fans to the case.
    Hope it helps
    Hope it helps
    Hmm thanks for the advice. I assume that heatsink would have a noticeable difference from the stock hsf? Looks great, I'll consider it cheers.
  3. A deepcool mc 3002 gx would keep your chip cool , nit sure about fit , cooler is 144mm tall so you need about 150mm from top of cpu to case side . Keeps my 8350 and 1100t cool . these will also work low profile 129mm high 120 mm fan
    http://deepcool-us.com/Product/TIGER_SHARK/
    Or this , cools a bit better 131mm high 140 mm fan, have one on order
    http://deepcool-us.com/Product/FIEND_SHARK/
    or this 137 mm high 120mm fan
    http://deepcool-us.com/Product/ICEWING5_PRO/
Heatsinks Cooling Cases Overclocking Product
