Hello,
For a school project I need to build a custom water loop. Phase 1 CPU only, Phase 2 include a single GPU, and possibly phase 3 add 2nd GPU.
I'll be using hardware from another project (from the fall semester):
cpu: i7 3770k
gpu: GTX 680
ram: 2x8GB DDR3 1600 MHz
case: NZXT Switch 810
psu: Enermax NAXN 82+ 750W Bronze
ssd: Intel 520 180GB SSD
hdd: 2xSATA III Seagate Barracuda 2TB (needed a lot of storage for data)
I've read the WC sticky and went through the recommended starter kits. Unfortunately, the only one available I can get in my hometown is the Alphacool Economy Set I (€180). I also found the Rasa 750 RX240 WaterCooling Kit (€230) I could pick up in a retailer's warehouse about 2hrs drive. Other than that the only other options would be ordering online from abroad (EU/UK) - places such as overclockers, although I like some of their custom kits, such as this one OcUK Tech Lab - V8 Watercooling Kit 240 (€230).
I would like to ask for advice on which one of the kits to get. More than about the price (a few 10's of euros more or less) I'd need the kit with which I could learn the most and which wouldn't be too hard to extend for phase 2 and possible phase 3 (although if I'm not mistaken the sticky kit recommendation already takes expandability into consideration) - I'm thinking the custom kit from overclockers could be good for that as I can see how items from different manufacturers are/can be combined into a loop.
Also, do I need to worry about the psu (750W) if I wish to add the 2nd GPU and maybe another rad, i.e. having 6-8 fans in the case?
Thank you
cpu: i7 3770k
gpu: GTX 680
Thank you
