Hello, I have spent a lot of time over the past week trying to figure this out, I put together this i7 1366 system and when I first got the stock heatsink my temps would idle around 47-55 ish and under load get up to 75-80 so I decided to go buy an aftermarket cooler asap so I went to best buy and picked up an h50 corsair cpu cooler because I have read that a lot of people have had it cool their cpu's good enough, well I have tried everything, pushpull setups exhaust intake setup, turning all fans around, changing settings around, etc. It is pretty warm inside my room as summer is coming along, It does get pretty hot in here so I am asuming that if the Air conditioning was on right now the temps would go down prolly 6C, anyway unless I disable hyperthreading and take it down to stock settings my temps will not stay under 50, they stay around 47 and will get into the low 50's while surfing the web, etc.. However when I am at full load this thing runs way cool, its like the cpu doesnt change speeds from idle to playing crysis, it stays around 55C in crysis, but in prime 95 when its hot in my room it will start around 60 and go up to about 68 and stay there for an hour..
I really am willing to spend some money on an aftermarket cooler so that I will be able to overclock this cpu safely and have it last me a long time. In the mean time am I okay with these temps? Im at 50, 45, 49, 45C right now and I am sweating because it is hot in my room right now and I haven't began using air conditioning yet. I just started up prime 95 about 30 seconds ago and I am at 67C but usually it doesnt go above 75 when it is this hot in my room. Also the northbridge temps on this board get really warm as well, the chipset will usually idle around 60-65. Is this hard on my cpu as long as it doesnt get any hotter? I know for temps under load this isn't that bad, I get even the same load temps when I have this overclocked to 3.5 ghz but am I safe to have these temps for the next week or so until I can figure out what to do? I would really like to fix this h50 because I like the idea of it and the looks and how quiet it is, thats important to me but I would also like to best performance the top performing heatsinks I will spend 100$ if I have to and if it well worth that price and not too hard to install.
Any feedback would be great, I hate having to worry about these temps after I just spent 700$ on this new setup.
Oh and the h50 I mounted it pretty good, I did it exactly how corsair shows in their video in terms of locking down the heatsink on the cpu, It did not wiggle or move at all, I screwed it in really tight and I am pretty sure the thermalpaste that came with it didnt even move because of how steady I had it when I put it in, I have a thermaltake supranors case with 4 120mm fans, I have the h50 doing a pushpull exhausting out the back of my case with a fan in the front of my case blowing air in and 2 120mm fans on the side of my case blowing in, the top one blowing right in at the radiator fan.
just to feel comfortable and I okay with these idle temps?
thanks
thanks
