Newbies questions about Water Cooling
January 7, 2013 8:14:56 PM
Hello. I have been thinking to fully upgrade my old peace of sh** PC. Like buy everything new.
The main thing would be: 3570k OCd, 7970(GHz) maybey, asrock extreme4 z77, corsair cx 600 psu and define r4 case.
As you probably already saw that this is on the Water cooling forum, and yes. I would love a water cooled PC. I have in my local PC part store this EK ready set with 240 rads and so on.. http://www.jimms.fi/tuote/EK-KIT-H3O-240-LTX
So, are the ready kits terrible or is there just some parts that are needed to buy again or is it complete good set?
Also about the rad, I have thought the from of the R4, tho if it doesn't fit.. I'm up to an other case. So, I appreciate all replys and help of any kind. And lastly, budget for PC is about 2000$ PLUS Water cooling.
Thank you :bounce:
